Cheap way to make my truck faster!
  #21
Old 04-18-2008, 08:45 AM
mstephen89's Avatar
mstephen89
mstephen89 is offline
Default RE: Cheap way to make my truck faster!
if you have a deisel pushing 580 hp, and its not a semi, i want to see that truck. I think you mean torque. Either way, i garuntee that diesel wont go in the woodsas good as yours.
  #22
Old 04-18-2008, 01:48 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
to the OP... crank sensor mod (free), 180 deg t-stat ($10 bux), open element air filter (search FIPK no more to find the thread, not sure on the cost). these will get you going cheep... autolite 3923 plugs, msd superconductor wires are a couple more tricks...
  #23
Old 04-18-2008, 01:56 PM
1BigRamaniac's Avatar
1BigRamaniac
1BigRamaniac is offline
....sigh....I...I just.....I just don't have the energy to respond to this....WAIT A MINUTE!!!!
How old are you?
Write your **** and vinegar factor here_______. Here is a handy chart:
PAV FACTOR
16-19 90%
20-23 80%
24-26 70%
27-30 60%
etc.
Married= -15% Kids=-10% each Men suffer a 1% PAV loss for each year married. Hopefully by 40 you have no PAV factor. You will then know what a truck is for. If you are in your 50's and just bought a red sports car-you are not fooling anybody. You arefaking your PAV.
  #24
Old 04-20-2008, 09:41 PM
Creeper's Avatar
Creeper
Creeper is offline
ha ha yasorry
  #25
Old 04-20-2008, 10:17 PM
Tarner's Avatar
Tarner
Tarner is offline
Lets see here my PAV base line is at 60%. I've been married 10 years. So that brings me down to 35%. Then you add three kids into the mix and I'm now down to 5%.
My truck is so neglected.[sm=alcoholic.gif]
  #26
Old 04-21-2008, 01:03 PM
1BigRamaniac
The lower the PAV factor the better!
  #27
Old 04-25-2008, 11:19 PM
94Ramsey's Avatar
94Ramsey
94Ramsey is offline
hey dont forget the 1.21 giggawatts. call doc he could help ya out with that LOL no offence man but a 2500 isent built for speed and as far as not keeping up with your friends powerless stroker lean into the gas a little or follow the basics like above stated.
  #28
Old 05-24-2010, 02:07 AM
BigDaddyRoss's Avatar
BigDaddyRoss
BigDaddyRoss is offline
Default 1997 dodge dakota
Alright lol i think that everyone has gotten off topic.With my 97 Dodge Dakota heres what I think are the cheapest and easiest was to help make your truck faster:
Cold Air Intake- go K and N
Throttle Body Spacer
Get performance headers (not the cheapest but necessary)
Get a chip the more high dollar tuners dont make much more of a difference so just get a cheap jet stage 2.
Electric fan and water pump - takes some drag off the motor and really improves engine life but you may need a better battery and alternator.
180 degree thermostat
Set of underdrive pulleys but dont go too cheap
Better mass air flow sensor
get superconductor plug wires no smaller than 8.0
a new ignition system - ive had luck with mallory hyfire
iridium spark plugs
and lastly use high octane
This is what I did with my truck with 1600 dollars and a year. I got to 410 hp on the dyno and managed 22 mpg after a 3 inch lift. But be careful because after this while doing a burnout I ripped pretty much the whole rear end to pieces. But now shes just fine. Good luck and have fun.
  #29
Old 05-24-2010, 02:22 AM
DODGEPWR's Avatar
DODGEPWR
DODGEPWR is offline
iridium spark plugs
  #30
Old 05-24-2010, 02:25 AM
RamSport97's Avatar
RamSport97
RamSport97 is offline
iridium spark plugs
Way to bring back a 2 year old post. I can't tell if you are being serious or not, but I found this post hilarious. First, the throttle body spacer, come on man, its junk, go put it in the back seat of your civic. Second, the Jet Stage 2 crud, also junk, your computer will re learn it, and the high dollar ones are the way to go, specifically, SuperChips, SCT, Hypertech. And Third, 410 hp out of a basically stock Ram? No, not gonna happen.
Quick Reply: Cheap way to make my truck faster!
