Bypassing factory Infinity Amps
#21
RE: Bypassing factory Infinity Amps
ORIGINAL: dusty_duster
Did you install an aftermarket headunit? If so, just run new wires to the speakers and bypass the amp altogether.
ORIGINAL: Trey318
Exactly
Exactly
#23
ORIGINAL: Trey318
Thinkin about it, if I run the wires directly from my head unit from my speaker, will I lose my tweeters?
Will
#24
ORIGINAL: priest1981
OK, I found a diagram at work. On my 98 Q.C. the left wires are DG and BR/RD and the right are VT and DB/RD. If you do not leave these connected to your amp the tweeters on the A pillar will stop working, I "T"ed mine in so they were still connected to the amp. Hope this helps.
Will
Will
#25
Im having the same problem. 2001 Dodge Ram. It had an alpine deck already installed when I bought it and all the rest of the infinity system was still there and worked great. The speaker went bad in the pass door. So I bought some alpines 6x9's to put in. I took the 6x9 with amp out, but now which wires do I need to hook up to the speakers? I want the tweeters to work too. Right now after I took the speaker/amp out of the pass door, I have no sound on any speaker and my door locks and windows dont work??? Cant figure it out. There are 12 wires going into the speaker amp, one is ground and 4 have power.
For some reason I cant see the wiring diagram that was posted up.
Help me please.
Help me please.
