squeak while accelerating
Old 10-17-2008, 03:12 PM
RamWood's Avatar
RamWood
RamWood is offline
OK I thought I had her all figured out.... got under the truck and I can't get the U-joints to move at ALL nothing nadda I was jerking on them pretty good. I did notice that the Transfer case seems to move a lot. (should it do that)
I am also noticing that the squeak noise goes away when the truck is warmed up??????
any new ideas?
Old 09-04-2009, 11:28 PM
jt13speed's Avatar
jt13speed
jt13speed is offline
Ok so this thread is a year old...but i have an 02 ram 1500 and i have recently developed this same squeak that gets faster and faster as i accelerate and then seems to disappear after ive driven around for a while. Did you solve your problem?? I have to climb under there and check it out tomarrow
Old 11-16-2010, 06:20 PM
FULLERME09's Avatar
FULLERME09
FULLERME09 is offline
Default same promblem
hey i got the same problem with my chevy once you hit 35 it stops and once you put it in neautral it stops
Old 09-24-2012, 06:45 PM
fakexnewfashionx's Avatar
fakexnewfashionx
fakexnewfashionx is offline
i kind of have the same problem but i replaced my universal and it still squeaks. any ideas?
Old 09-25-2012, 06:27 PM
crackajack92's Avatar
crackajack92
crackajack92 is offline
i also have one now eversince my hub assembly and stub axle replacement ive checked everything again and still squeeks in the front very high pitched and loud.
Old 09-25-2012, 08:41 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
check the disk brake pads to see if the pad is worn out and the squealer tab is dragging on the rotor.
start by jacking up the tire and spinning it to see if you can duplicate the sound.
Old 09-26-2012, 05:38 PM
fakexnewfashionx
i had the same thing but i went to go change my wheel bearings and come to find out my rear is blown the spider gears were cracked and the fluid was old and smelt gross as hell. i would suggest open of the rear diff and take a good look inside.
Old 10-16-2013, 04:40 PM
campermama's Avatar
campermama
campermama is offline
Mine never made a noise until I just had the radiator replaced, now I have a squeal. Mechanic thinks coolant got on the belt. Truck runs fine except for this noise. So I drove it home (was on the road at the time) 600 miles.....squeals only during acceleration, after all these miles squeal is still there.
Any ideas? I checked all the work the mechanic did (I watched him work) and nothing is loose.
Old 10-16-2013, 09:24 PM
cntry_prernnr's Avatar
cntry_prernnr
cntry_prernnr is offline
i have a similar issue. mine squeals between about 2500 and 4K RPM and i think its the fan in my case. thinking of changing to electric fan to fix my problem.
Old 04-30-2014, 02:33 AM
turkamania's Avatar
turkamania
turkamania is offline
Default only squeaks when i hit the gas
Im having the same problem. it only makes the noise when i accelerate but it does stop when i let off the gas. it stops completely when ever i start going down the road for a while.
Quick Reply: squeak while accelerating
