intermediate shaft
Old 10-28-2008, 01:35 AM
1999dodgeram's Avatar
1999dodgeram
1999dodgeram is offline
Default intermediate shaft
i was wondering if anyone knows how to change an intermediate shaft in the front axle of a 1999 Dodge Ram 1500 4x4
Old 01-01-2009, 11:33 PM
olyelr's Avatar
olyelr
olyelr is offline
Remove the tire, then the caliper/brake assembly, then the wheel bearing/hub assembly, and then slide shafts outs. You will most likely have to remove the CAD cover to reach the inner shaft.
Old 01-02-2009, 05:16 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You have to remove the CAD, and be careful you don't damage the seal. Now is a good time to replace it, but you'll need a special tool. Also there is a black composite bushing in the end of the outer shaft where it connects to the intermediate shaft, keep track of it(make sure it's not loose before you take it out). And after you remove the outer axle, make sure the bearing the intermediate shaft rides in is good. Just grab the end of it with your fingers and see if it moves up and down or sideways. Oh, btw, just wondering why you are replacing it?
Quick Reply: intermediate shaft
