Need some help....Temp gauge not working
I know there is other threads about this........I have aready used the search on here but I can't figure it out.
The temp gauge has quit on my 99 Ram 5.9
The gauge sits all the way cold until you shut the truck off......The once you start it up again it reads alittle bit of heat but goes right back to nothing.
So far I have tried 3 different sending units with zero luck.
Any other ideas I can try? Thanks
try the gauge/cluster self test. hold odometer trip meter button in and turn key to on. continue holding button in until odometer reads CHEK, and then release it. cluster will self test, turning all lights on, and then sweep all gauges to about 1/4, then 1/2, then full. see how your temp gauge acts.
Trending Topics
