They are a pretty good transmission once you get them rebuilt right. The biggest problem with this transmission was the lack of the publics knowledge on the TV cable system. These transmissions were super sensitive to the TV cable setting and people would either mess around with it and get the wrong setting or not get it adjusted for 100000 miles and burn it up from it being out of adjustment.
The TV cable is as tight as it goes on mine, and I love it like that. Nice hard shifts that throw you around, and it kicks down with the slightest tap of the pedal... However usually I am using the ratchet shifter
I have water in my transmission fluid of a 98 24 valve diesel 2500. How would I change the filter and drain transmission fluid or what should the cost be?
Drop the pan, change what fluid comes out. Takes about six quarts to refill. (start with four, then start checking fluid level, trans warmed up, in neutral) One change isn't going to cut it though, gonna have to do it a couple times to get most of the water out. Hopefully, that will reduce the content enough that the rest will boil out..... Unfortunately, water tends to do a real number on the clutch/band linings, and there is a good chance that a rebuild is going to be in your VERY near future.
. The reason is because I bought the wrong tranny. I accidentally bought a re to replace the tranny in my 94. I didn't know at the time that there's a difference
