Make sure the #4 plug wire didn't get f'd up when you pulled it to do the install. And check all the grounds and also the wires to the distributer and crank sensor. I hope the push rod isn't bent at #4.
vader what your truck look like never saw a pic ??? how the performance for you ??? did you recconect the ground wire on the left valve cover it was a pita. let us know when you replace the ignition wire if it works, if not were going to think on it
