best 46rh shift kit
  #61
Old 07-22-2012, 08:52 AM
TheBeast413's Avatar
TheBeast413
TheBeast413 is offline
You should have a 46RE in there. The two solenoids on the same bracket are O/D, and TCC. If your trans is an RH model, your check engine light should be on constantly, with various trans codes.
I have codes out the ***, I have two governor codes, a TCC code and a 3-4 miss shift code. my truck is a base model of the base model, 97 5.2, 1500
Quick Reply: best 46rh shift kit
