46re Transmission Problems
#21
#22
Trans is in limp mod. First thing to deal with is the 1765 code. There is a relay in the power distribution center (under the hood, behind the battery) that supplies power to the trans. Without power, TCC,O/D won't work. (I suspect both codes are the same problem.)
Check the connector at the trans as well. They have been known to deteriorate, and the wires short... makes life interesting.
Welcome to DF!
Welcome to DF!
#23
#24
