Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram Tech
Sign in using an external account
Register Forgot Password?
'98 Dodge Ram won't start.
Thread Tools Search this Thread
Old 02-19-2009, 02:47 PM
Jvello15 Jvello15 is offline
1998 Dodge Ram 1500
Vehicle: '98 Dodge Ram Quad Cab
Default '98 Dodge Ram won't start.
So it was blistering cold out a couple weeks back and I had returned home and turned my automatic start to keep the truck running and warm while I ran inside to change. Once inside I heard my keys beeping as if it were trying to start my truck again and once I got back outside it was no longer running. Got in and tried to start it but my battery was dying so I tried jumping it, no good.
Changed the battery because it was 8 years old thinking that'd be the problem, no fix. Tried a cheap fix of the ignition coil, no fix. Pulled a spark plug wire off of a plug and put one back in the wire and tried starting to see if it would fire and noticed I'm not getting any power from the distributor. I had recently changed my distributor cap/wires/plugs (about 3-4 months ago max) and check it out again and nothing looked to be wrong.
As far as a fuel problem I was previously having complications with my truck starting the first time I turned the keys over. What I'd usually do is give it a second or so turn and stop and then pause a second and turn the keys over a second time and then the truck would start.
After complications of it not starting I sprayed starter fluid into housing to try and see if it was a fuel problem and just wasn't getting to the engine but that didn't seem to help either so I'm thinking it's not fuel.
Anybody have any other suggestions on what I should try or look for?
Thank you and I greatly appreciate your guy's suggestions.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 02-19-2009, 04:19 PM
SupaSteve's Avatar
SupaSteve SupaSteve is offline
Garage is empty, add now
Vehicle: 2001 Dodge Ram 2500/1996 Dodge Ram Indy 500 Pace Truck
Send a message via AIM to SupaSteve
It's going to be your Crank Angle Sensor (CNK), the absolute exact thing happened to me three nights ago. I used the remote start on my 2001 Ram 2500 with the 5.9 Gas, and I got into the truck and all of a sudden it stalled, I checked everything you checked and it came down to either something simple as the Crank Angle Sensor or the ECU, so I replaced the sensor which was only $43.00 from Advance Auto Parts and it's been running great. The sensor is located behind your engine on the side of the Bell Housing on the passenger side. Your going to want to take the front passenger side plastic wheel well off and you have access right to it. The sensor has a magnetic end that slides right into the engine on an angle and the other end plugs under the distributor. Hope this helps! Good luck!
Old 02-19-2009, 04:52 PM
1998 Dodge Ram 1500
Ahh.. Looks like I'm on my way to a parts store to pick it up and hope that that's the fixer I need. Thanks! and I'll let you know what happens.
Old 02-19-2009, 06:00 PM
1998 Dodge Ram 1500
It seems I'm having a problem locating the crank sensor.. If you or someone could give me a more detailed location or anything of the sort I'd really appreciate it.
Old 02-19-2009, 06:04 PM
zman17's Avatar
zman17 zman17 is offline
Section Moderator
Dodge Forum Moderator
2000 Dodge Ram 2500
Vehicle: 2000 2500HD 4x4 5.9
I'm on the fence whether or not that's the prob you are having. But it is located behind the passenger side exhaust manifold, in between the tranny and block. It is not easy to to see. You'll be doing it blind for the most part.
__________________
2000 2500HD 4X4 5.9 and 4:10's,HF tuned SCT,Red-Head gear box, HS 1.7's,
50mm Fastman TB, Hughes Plate,2" Hell Bent ,Volant CAI
Flowmaster 50 series, Rock Solid Ram Steering fix,B&M trans cooler,fuzzy dice good for 5HP
Old 02-19-2009, 06:08 PM
wjxavier's Avatar
wjxavier wjxavier is offline
1995 Dodge Ram 1500
Send a message via AIM to wjxavier
that sounds like fun...
Old 02-19-2009, 06:30 PM
1998 Dodge Ram 1500
Quote:
what might you think is the problem?
Old 02-20-2009, 04:49 AM
zman17's Avatar
Section Moderator
2000 Dodge Ram 2500
Just saying that when it's the crank sensor, the trucks usually starts fine, then dies 10 or15 minutes later after warm up. And won't start until it cools down again. Now the cam position sensor is another story. It's located in the distributor and can be checked. Also you should check all fuses and relays. ASD and Fuel relay's are first to check. And pressure test the fuel pump.
__________________
Old 03-14-2009, 05:31 PM
1998 Dodge Ram 1500
Just thought I'd let ya guys know the update on the situation that I had.. Apparently it turned out to be that a spark plug wire had been touching the manifold and created a short and also the recently changed distributor cap and rotor were checked again, the rotor appeared to be defective or damaged so I replaced that.. All is well now! Thanks goes to everybody for your suggestions!
Old 03-14-2009, 06:13 PM
wjxavier's Avatar
1995 Dodge Ram 1500
glad you got her fixed
Tags
1500, 2000, 2001, 96, 98, dodge, forums, gas, located, ram, remote, spark, start, starter, van, warmed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
