Old 08-06-2015, 02:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
How do you reset the pcm
Old 02-21-2017, 05:54 PM
line8014's Avatar
line8014
line8014 is offline
The connection part in trans was broken off or melted i am going to look at bands not much adjustment bolt on rear band or front the front band is real lose
  #62
Old 02-21-2017, 05:59 PM
line8014's Avatar
line8014
line8014 is offline
Connection part was broken off or melted I am going to look at bands front is lose both front and rear adjustment bolts have very little bolt left to adjust
  #63
Old 02-21-2017, 07:23 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
They are probably worn out..... You *might* be able to get away with a slip-in band replacement for a little while, but, once the bands are gone, the rest of the trans isn't far behind.
  #64
Old 10-19-2017, 08:25 PM
Joseph LoBianco's Avatar
Joseph LoBianco
Joseph LoBianco is offline
Default Off subject
Sorry this is off topic, but I have a 2001 dakota 4.7L. It starts right up and runs fine. Once you shut it off, it wont start for about a half hour or so. I have changed engine temp sensor, crank sensor, radiator, the computer and no resolve. Also changed fuel pump relay. I am lost, any help would be greatly appreciated
  #65
Old 10-20-2017, 12:01 PM
HeyYou is offline
You want to post in the 2nd Gen Dakota Tech section.
  #66
Old 12-08-2019, 11:30 PM
Roy Maldonado's Avatar
Roy Maldonado
Roy Maldonado is offline
Default 2008 Ram Hemi 5.7 4 door pick up truck
Originally Posted by Viper37
Turn it to crank for fastest effect.
Anytime you do an air filter, change engine parts or something like that you reset the PCM.
where is PCM llocated
Quick Reply: How do you reset the pcm
