electric cooling fan
Old 03-15-2009, 02:52 PM
wjxavier's Avatar
wjxavier
wjxavier is offline
Default electric cooling fan
i'm also interested in taking my stock fan out and putting electric fans in. if anyone has info on this topic or can direct me to a DIY then i would greatly appreciate it. any tips or tricks is also appreciated. thanks!
Old 04-08-2009, 09:20 AM
bowak's Avatar
bowak
bowak is offline
Default electric cooling fans
I am asking the same question. I know a few guys that have put them on there Cummins and the results they say have been worth the effort. I have a '09 Hemi and am asking will this work for a gasser? The elimination of that fan has to reduce the strain on the engine therefore increasing milage and performance. My Cummins friend bought his fan system through Flex-a-lite.....www.flex-a-lite.com
Old 04-08-2009, 09:25 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Visit a junkyard and look for fans on the hi-po 8-cylinder Fords.
Old 04-08-2009, 09:35 AM
PartsChaser's Avatar
PartsChaser
PartsChaser is offline
After having my regular clutch fan fail, and burn a valve, I went the e-fan route. I made my own, with 2 16'' fans I bought on ebay for $50. Made my own mount, inside the stock shroud, and wired them to switches inside the cab.
Many elect to get the controller that will automatically engage them at a certain temp, which is a great option, but I wanted the ability to manually control it (since I am the only driver of my truck).
I did notice a little gain in power, and MPG, but nothing that was so great that I would recommend it to everyone.
If you have the $$$, the flex-a-lite is the best way to go for sure. But, if you are decently handy, you can make your own for well under $100!
Old 04-08-2009, 09:55 AM
mcss8541's Avatar
mcss8541
mcss8541 is offline
i have the flex-a-lite dual electric fan setup with the thermostat; here are some pics of my setup.....and yes you DO NOT need the shroud anymore just modify brackets for the washer fluid and coolant bottles if you need more let me know
Old 04-08-2009, 09:56 AM
lv360ram's Avatar
lv360ram
lv360ram is offline
http://www.flex-a-lite.com/auto/html/262-diesel.html
Notice the brackets for the plastic jugs?
How much is your time worth to build your own?
If it's free, I'd like to buy some from you because I don't have enough.
Old 04-08-2009, 11:04 AM
mcss8541's Avatar
mcss8541
mcss8541 is offline
I saw that one as well when I bought mine and was thrown off by the Diesel part. Looks good though.
Old 04-08-2009, 11:44 AM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
well, i just put in a mark8 fan and i love it....what part of it are you wanting help with?
Old 04-08-2009, 02:22 PM
BlueBeast2's Avatar
BlueBeast2
BlueBeast2 is offline
I looked up that diesel one on ebay the other night. Jegs wants almost 550 bucks for that damn thing.
Old 04-08-2009, 02:40 PM
mcss8541's Avatar
mcss8541
mcss8541 is offline
well they don't come cheap. mine wasn't as expensive but it ran a close 2nd but it's well worth it trust me. mine has already paid for itself in the fuel i've saved. I think the diesel one is more expensive because of it's frame.
Quick Reply: electric cooling fan
