Oil Dip Stick
Old 04-18-2009, 12:12 AM
J415's Avatar
J415
J415 is offline
97 ram with yellow tranny and oil dip stick.
  #22
Old 04-18-2009, 02:56 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
Both mine ('98) are yellow. One clearly says "Engine Oil" and the other "Trans Fluid".
  #23
Old 04-24-2009, 02:10 AM
VOATMJ1's Avatar
VOATMJ1
VOATMJ1 is offline
Went to the dealer and he had a new oil dipstick in stock, and it was identical to mine, numbers matched and the markings on the both new and old stick matched. So does anyone have any advise as to what else could be causing the oil to read high and way past the full mark on the dip stick?
  #24
Old 04-24-2009, 02:31 AM
RM_Indy's Avatar
RM_Indy
RM_Indy is offline
Assembly line conspiracy theory #2
Ran out of 360 dip stick tubes and substituted the much shorter 318 tubes in its place
  #25
Old 04-24-2009, 02:33 AM
J415's Avatar
J415
J415 is offline
drain your oil pan as if you were gonna change the oil and measure how much oil comes out. Then put it back in the engine and see if your numbers match.
  #26
Old 04-24-2009, 11:03 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
my 318 reads just to the top of the safe range when full, as do all the tractors and the combine when we do oil changes, cept the tractors take 6 gallons of oil, not a typo
  #27
Old 04-24-2009, 11:48 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Duh I wonder why?
  #28
Old 04-24-2009, 11:54 PM
95MaroonMonster
we don't have one, but the International 4300 takes 36 quarts in the pan, and it was built in the 60s
Quick Reply: Oil Dip Stick
