Idle oil pressure low when at operating temperature
#21
i had the same thing awhile back, i tried 2 oil sending units, that didnt work, i put a mechanical gauge on it, it reads fine. so i changed the oil with normal 10w30 and used 4 quarts, then add 1 quart of lucas oil stabil. and now when its cold i get about 65ish psi, and after driving for 45 min or so it will still read about 30.
i had been told the hot curb idle psi is a minimum of 7psi. but normally hot curb idle you gonna want like 15-20. dont really wanna play on the low side of things.
oh also forgot, i changed the oil pump and pickup tube also, didnt have any change for it dropping to 0.
i read somewhere that it could of been a sodering problem in the instrument cluster itself.
#22
#24
#27
Same issue in a 2500 van 5.2
The oil level is good and the oil weight doesn't help either.
I am starting to think the oil sensor is faulty or possibly the tube is plugged. I drove for 1 hour and 20 min in the desert and no knocking so there must've been a decent amount of oil pumping through.
