Front speakers not working
Old 05-04-2009, 08:28 PM
Gearbox Paul's Avatar
Gearbox Paul
Gearbox Paul is offline
Thanks for all your replies.
This is not a wiring issue or a radio issue. I have a signal right up to the speaker. I just put in a new speaker at it works instantly, without doing anything else. I have only replaced one speaker so far and a used an identical stock speaker from a wrecker. It too failed shortly after.
Good thought about the humidity/temperature changes doing the speaker in. I live on Vancouver Island where the humidity can be very high. Seeing how many others are having problems, I have to assume these speakers are crap.
Old 05-04-2009, 08:52 PM
dsertdog56's Avatar
dsertdog56
dsertdog56 is offline
I have the downloaded manual from this site and used the factory tests on the wiriing. I have no continuity to my left side, but don't have the right tool(s) to remove the door panel clips to test the speaker. I don't believe the factory speakers were made to last more than the average original ownership lifespan .
Old 05-05-2009, 01:59 PM
iwhitne's Avatar
iwhitne
iwhitne is offline
Originally Posted by Miami_Son
So am I. My 2000 Quad Cab has 6-1/2" round speakers in the front doors and 5-1/4" round speakers in the rear doors. Is the 2001 different?
umm.. I un bolted the old ones... and the new ones dropped right in place....?! hahaha I'm sure they are 6x9's.. at least that's what the box said
Old 01-09-2016, 05:54 PM
Rolling coal's Avatar
Rolling coal
Rolling coal is offline
Default front tweeters not working
I have a 1998 Dodge Ram 2500 and after I bought the wiring harness adapter and installed an aftermarket stereo the front tweeters stopped working! I test them and they are still good. Any ideas why this happened or how to fix it?!
Old 01-09-2016, 09:12 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Do you get sound out of the rest of the speakers in front?
Old 01-09-2016, 09:49 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
I wonder if the adapter harness had the hookups for the separate tweeters.
Old 01-10-2016, 10:54 AM
Spillage's Avatar
Spillage
Spillage is offline
I thought the tweeters where only with the Infinity system.
Infinity system has amps on the front speakers (not in the head unit)... the amp on the speaker drives the tweeter, so the head unit harness adapter has nothing to do with the tweeter working or not.
If you replaced the door speakers with other than a factory infinity speaker, the tweeters need to be wired back in by bridging terminals on the harness connector in the door.
Quick Reply: Front speakers not working
