Overdrive sensor
I can't recall exactly, thinking it was around $200 when I bought mine. I replaced every sensor in my trans, gasket/fluid for $400 total.
To replace it you drop the pan and valve body. It bolts up to the valve body and has a wiring harness that wraps around it and will then plug into your harness from the exterior of the trans.
Do a search on the code you asked about, seems like a pita code to track down and has multiple meanings. Will tell you this, guy at the dealership told me outright the overdrive sensor set up rarely goes bad, and he was right, mine was fine.
I didn't get the same code as you.
I don't know enough about the tranny and probably should not comment, but, there is a TC lock up solenoid and a governor pressure sensor in the pan, that can be replaced. I've never heard of a overdrive sensor. (or atleast hearing either one called that). As far as I know, if the overdrive does not work, you have a problem with the overdrive unit in the rear of the transmission, in or closed to the tail shaft. I'm probably wrong, but that is just info I have read on DF.
I don't know enough about the tranny to really comment, but, there is a TC lock up solenoid and a governor pressure sensor in the pan, that can be replaced. I've never heard of a overdrive sensor. (or atleast hearing either one called that). As far as I know, if the overdrive does not work, you have a problem with the overdrive unit in the rear of the transmission, in or closed to the tail shaft. I'm probably wrong, but that is just info I have read on DF.
Will agree though, doubt your issue is with the solenoid, and more likely something else. I got a different code for the solenoid that was more about electrical issues, referring to voltage.
