Lift Kit For 2WD truck
#33
I have an 01 and this is the kit I ordered http://cgi.ebay.com/ebaymotors/94-01...#ht_3773wt_964 It was pretty cheap(do a best offer), easy to install, and retained a pretty good ride.I didnt use the rear blocks though. Im able to swing a 33x12.50x15 with minimal rubbing. If you want more than the 3" I'd suggest a spindle lift, but depending on your backspacing I think you may need 17" rims.
#34
#36
I think 3" is the maximum for the stock control arms/ball joints.... beyond that, and you try and move them past their limits. (and things break..... not a good scene with steering parts.....)
Not sure on the 2by's, but, on the 4x4s, stock shocks will tolerate 3" as well.
Spindles: Only if you want more lift than can be had with just springs.
