Wear a puffy coat and thick gloves so you don't leave personally identifiable marks, then burn the cloths after you're done. Do it in a bathroom so there's so much random DNA they can't pin it on you and no cameras. Put a chunk of Dry ice near his liver to confuse TOD, but not directly on his skin as to avoid freezer burn marks. When it melts it will evaporate into nothing but CO2.
I find it distressing that you know so much about this topic!
What is this?
Is it a check valve? That line goes through the firewall. I have the wild vents issue, but have not found any vacuum leaks. Cruise control works, 4x4 axle engages.
