check valves for wild vents
Old 06-26-2009, 02:36 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Default check valves for wild vents
does anyone know which direction the vacuum should flow in the lines at the t and on the side of the manifold and which direction should make them close? i replaced the one on the t and the one on the side of the manifold and i still have the wild vents. i have also looked at the wild vent fixes and none of them say which way the valves should go.
EDIT for future people with wacky vents, the part # for the check valves is 4549209
Old 06-26-2009, 04:49 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Do you have cruise control?
Old 06-26-2009, 04:57 PM
Laramie1997's Avatar
Laramie1997
Laramie1997 is offline
I put mine on the right hand side of the t.
I may sound like an *** here, but those valves only have two different ways to be mounted. You might have to try it both ways. Like what zman is trying to get at, you might have a vacuum leak with the cruise control. Common place for that was under the battery box.
Old 06-26-2009, 05:18 PM
zman17's Avatar
zman17
zman17 is offline
As far as direction goes, did you replace them with oem? If you did I can try to describe by the way they look which way they go. They are glued together or press fit, and the smaller half which is about a third of the size of the other half, goes towards the firewall.
Old 06-26-2009, 07:14 PM
Sheriff420's Avatar
Sheriff420
i do have cruise. i don't believe i have a leak. i did replace them with oem but i didn't try them the other way because i thought i put them back on the way the old ones came off.
Old 06-26-2009, 07:18 PM
Laramie1997
Try switching it around and see what that gets you.
Old 06-26-2009, 07:48 PM
zman17's Avatar
zman17
zman17 is offline
If you replaced them with new oem cv's and put them on the same way, then there is another prob. And btw, the vac lines to the CAD can also be a prob and the vacuum switch on the transfer also had 2 check valves coming off of it.
Old 07-07-2009, 12:20 PM
ryker's Avatar
ryker
ryker is offline
I've got the same issue. I checked my topside check valve and it holds a vacuum. So I didn't buy a new one. No cruise control either. But I do have 4x4.
Old 07-07-2009, 04:14 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
vac get pulled in toward the intake at the charge goes down the cylinder. Is that what you were looking for?
Old 07-08-2009, 08:04 AM
Sheriff420's Avatar
Sheriff420
thats how i have them, the vac is able to flow toward the intake. i checked out the lines in the engine and the cruise servo the other day and didn't find any cracks or anything. the cruise servo was replaced a couple years ago and it still looks brand new. the vac lines to the cad look good and i didn't see a check valve on them, i'll have to go take a better look.
Quick Reply: check valves for wild vents
