Front end Humming - 1998 Dodge 4x4
Old 06-29-2009, 10:58 AM
omanalansan's Avatar
omanalansan
omanalansan is offline
Default Front end Humming - 1998 Dodge 4x4
Front end hums between 15 mph to 40 mph. Above 40mph is completely gone. When I hit the gas its there. I just replaced my passenger side axle ujoint because it was clicking (that was fun, broke so many tools but learned alot) thought that would fix the humming, nope but no more clicking.
I had NTB check out the front end, hub bearing are good. I did the test Lifted the front end and no wiggle on both tires. I"m stumped i can't figure it out. Help!
New tires Daytons Timberland.
Many thanks
-O
Old 06-29-2009, 05:27 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Maybe the driver side joint is starting to go bad.
Old 06-29-2009, 08:09 PM
onegoodmason's Avatar
onegoodmason
onegoodmason is offline
you could try removing the frt drive shaft . There's a ball centering joint in the double-cardon joint that can cause the humming as you describe . The are about $60 to replace . Since you can't lube them , they can dry out . I had this happen to my Jeep Grand Cherokee , it took alot of diagnosing to find it . Good luck , hope it works for you too .
Old 09-16-2009, 12:22 AM
r1rider05's Avatar
r1rider05
r1rider05 is offline
any one figure this out, I have the exact same thing, have replaced all hubs u joints ball joints tierods, alighnment track bar and its still thier seems to be when its cold around low speeds, was thinking bearings in axle
Quick Reply: Front end Humming - 1998 Dodge 4x4
