Last edit by: IB Advertising
Browse all: General Overview
- Dodge Ram 1994-2001: Fuse Box Diagram
Important information to help you understand your Ram.
I.O.D. (Ignition Off Drain) Fuse
Mine was blown out when the PO removed the radio. Now I have the trip computer back along with the outside temp display. Radio powerlead is still dead, I suspect other wiring creativity from the PO under the steering coulum.
Was better off without knowing it was 96F at the time.
sprntpshr
sprntpshr
1998 Dodge RAM 2500 Cummins - Fuse 12 in Junction Box
Correct to above comment:
My 1998 Dodge RAM 2500 Cummins - Fuse 12 in Junction Box (I.O.D) is exactly as the picture in the beginning of this thread. It has a black plastic guard as shown. The two larger arms top and bottom can be squeezed together with the finger and thumb or a pair of pliers as it is pulled out, but it only come half way out. At this point the fuse legs or tabs can be tested with a meter for continuity. Mine showed the fuse was blown.
The little cover in the center of the black plastic is the trick. It hinges on the right (NOT on the left as stated above). I broke one of the little hinges trying the procedure mentioned above. Then, the movement allowed the left side to open. Try to open the left side first. It snaps over two little tabs that can be seen with mirror. Then, pull the fuse with small pliers.
Installation is easy. Just shove the fuse in, close the little cover (if it hasn't broken off) and push everything in.
This is another CRAZY mysterious design by Dodge. The big shop book doesn't help one bit. It tells and the obvious steps but seems to always skip the TRICKS.
Good luck . . .
Good luck . . .
Battery change somehow caused IOD fuse to blow
I changed my battery today in my 2006 dodge ram 1500. I'm not sure if one of the cables hit some metal or what, but my IOD(ignition off draw) fuse blew. I didn't even know what this was prior to reading this thread. So thank you all for posting. It was very helpful.
My locks, radio, and some of my lights would not work after replacing the battery. When I started the truck, the dashboard displayed a "No Fuse" message.
I wasn't sure what that meant. After searching this forum I found out.
It was the IOD fuse located in the fuse box, near the battery. The fuse box is a black case about 6" wide and 10" long. Once you open it up by pressing down on the top and pulling out, you will see the fuses and a diagram on the inside of the top of the box. It will denote what each fuse is responsible for.
When replacing the IOD fuse, you'll want to pull up the casing until it won't pull up anymore. Don't force it. Then take a small screwdriver and pry open the top part of the casing. Once open, remove the fuse and replace it with a new one. Make sure not to get the "low profile" fuses. The relays won't be long enough to plug in the way they need to.
Once replaced, put the small plastic casing back on, push the larger plastic casing back into its regular position and that should be it.
Everything was functioning after I replaced the IOD fuse.
Thanks again guys!
Thanks again guys!
some having a problem with my DakotaI was driving it the other day with no problems then the next day I went to go to the store I hoped in and tryed to start it and nothing happened I have no dome light brake lights nothing so I replaced the ignition switch thinking it was the problem I was wrong .so my question is has any one had this happen and if so do u know how to fix it Ihhave tested pretty much everything so ya any help would be much appreciated thank you
