1998 ram slt quad cab seat belts clicking
Old 10-23-2009, 11:18 AM
wa.alldiesel's Avatar
wa.alldiesel
wa.alldiesel is offline
Default 1998 ram slt quad cab seat belts clicking
new to this forum where do i start looking. searched but found nothing. any help thanks
Old 10-23-2009, 11:47 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
what do you mean by seat belts clicking?
Old 10-23-2009, 01:40 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
the search is broken right now.
do you mean that they are clicking like when you pull them out all the way? only their doing it every time you buckle up?
Old 10-24-2009, 12:09 PM
wa.alldiesel
When I press the brake pedal the seat belt lockers in the seat by the top start clicking. It's like there is a bad connection some where from the brake pedal to a seat belt control or safety device. Bolth seats do it.
Old 10-24-2009, 12:18 PM
Sheriff420's Avatar
Sheriff420
sounds like the retractor has a problem. hit the junkyard. or call the guys at http://www.mintonmotorsinc.com/index.html for some used seatbelts. that is if you can change just the belt. i'm not sure if you can since it is built into the seat.
the seatbelts lock up in my truck if i get on the brakes but they don't make the clicking noise.
Old 10-25-2009, 05:05 PM
wa.alldiesel
Bolth seats do it at the same time witch leads me to believe there Is a controler for the seat belts activated by the brake system. I need to find a wiring diagram
Old 10-25-2009, 06:35 PM
de8212's Avatar
de8212
de8212 is offline
In my 99 there is a sensor of some sort under the middle seat. Mine went bad a few months after I bought my truck. I don't remember any kind of clicking though so I am not sure your issue is the same.
Old 10-26-2009, 10:10 AM
Sheriff420's Avatar
Sheriff420
my dads 98 has a seat belt fuse in the dash fuse panel. check that.
i assume it is there to trip the light on the dash when you don't buckle up. but it might have something to do with your noisy belts.
Old 10-26-2009, 11:50 AM
wa.alldiesel
Size:  18.7 KBlocation of control module
wire diagram of module.
here is what I found.
There may be a problem with the seat belt control module being that it is both seat belts.
You will want to check the fuses (#1 and #16) of course and then the module. Here is a diagram of the airbag that shows the fuses and a test for the SCTM.
SYSTEM OPERATION
A seat belt retractor latch solenoid is integral to each of the two outboard front seat belt retractors. The solenoid is grounded at all times through its wire harness connector and circuit. The solenoid receives battery current, which is switched by the Seatbelt Control Timer Module (SCTM), through a fuse in the junction block.
When the seat belt retractor latch solenoids are energized the retractor spools are unlatched, and the seat belt webbing can be withdrawn from the retractor. When the solenoids are de-energized the retractor spools latch, preventing the seat belt webbing from being withdrawn any further from the retractor.
The seat belt retractor latch solenoids cannot be repaired. If the solenoid is faulty or damaged, the entire seat belt retractor unit must be replaced.
Seat Belt Retractor Latch Solenoid
  1. Disconnect and isolate the battery negative cable. Unplug the wire harness connector from the Seatbelt Control Timer Module (SCTM).
  2. Check the resistance between the inoperative (driver or passenger) latch signal circuit cavity of the SCTM wire harness connector and a good ground. The correct resistance should be from 50 to 60 ohms . If OK, see Seatbelt Control Timer Module in the Diagnosis and Testing. If not OK, go to Step 3.
  3. Unplug the wire harness connector at the inoperative (driver or passenger) seat belt retractor latch solenoid. Check the resistance between the two terminals of the latch solenoid. The correct resistance should be from 50 to 60 ohms . If OK, go to Step 4. If not OK, replace the faulty seat belt retractor unit.
  4. Check the resistance between the ground circuit cavity of the latch solenoid wire harness connector and a good ground. There should be no measurable resistance. If OK, repair the inoperative (driver or passenger) latch signal circuit between the solenoid wire harness connector and the SCTM wire harness connector as required. If not OK, repair the circuit to ground as required.
Old 10-26-2009, 11:52 AM
wa.alldiesel
As soon as I can, I will test the SCTM it seems to be the culprit.
Quick Reply: 1998 ram slt quad cab seat belts clicking
