RUST ALERT
I noted a response from an obviously more intelligent writer than I concerning the rust on Dodge pickups. As noted previously my Dodge Dakota is a 2005 model 4 dr Laramie with 128k on the clock and I have NO rust. It has survived 9 KC winters and no rust. It has NOT been treated with Dandy Rust Preventer that I have in MY ignorance omitted to apply. It does however, get a regular under chassis wash down. Who ever it was that offered his rust prevention tip didn't add his name to his comments---? Glenn Lorei
This is rarely an issue with light annual coatings. I will happily be up to my *** in grease any day than look at or deal with seized / broken bolts rotted out components and rotten sheet metal. Besides, I've heard you complain more than a time or two about the amount of rust on yours truck.
If I may be prejudice for a moment, based on your responses I'm going to guess you are old hat and haven't been under your vehicle very much. If they salt the roads in Missouri at all I guarantee you your 10 year old truck is well on its way to being rotten underneath if you or the previous owners have never had any form of oil-based undercoating applied. Slide under and you will be stunned at how much rust you never thought was there. You may have avoided major creep on your body panels, but believe you me it is impending at that age. Frequent washes during winter are extremely important to get the layer of salt off which soaks up condensation due to temperature fluctuation, especially when your vehicle sits. Not many people tend to wash, as the "it'll just get dirty again" mentality kicks in. Assuming your winters are harsh, that is the only reason your truck is not as bad off as others. Around here, it is rare to see pre-2000 vehicles as most would rather deal with a monthly payment than a cancerous money pit.
That said, I see GM trucks from the early 90's running around with significantly less rust than my truck...... though, after owning mine for a while, I came to the conclusion that 'maintenance' was a four letter word to the previous owner.......
Rust Issue
Whenever I get my oil changed and give the underside a look see. So far my Dakota is rust free. I see the start of rusty areas but certainly no areas that are about to rust thru. I'm lucky I suppose. The KC area uses salt and salt brine. I spend a lot on drive thru car washes. It is alarming however to see well kept vehicles with rust thru over the rear wheel openings. It would seem that Dodge would be clammering to offer a patch panel (not for Free) to repair.
What a bunch of good will that would create.!! 1939ford
