Slow Start
Ok, cool. And when I shut it off, it shouldnt drop very quickly, correct? I will check the evap canister too. Before long, I wont have anything else to do to my truck...im gonna get rid of the death flash and do the hughes as soon as I figure out this starting issue. I need to do some searching and figure out what the best way is to get rid of death flash and get good performance.
Thanks
Thanks
fuel pressure should come up very quickly to 49 psi and maintain there whenever its running. when turned off, it should bleed off v-e-r-y slowly. when turned back "on" it should pop back up quickly.
if you suspect any vacuum leaks, then as a test - disconnect ALL vac lines from the manifold and cap off the manifold ports. this eliminates the possibility of downstream leaks. obviously it disables those downstream devices, but its a quick way to test.
superchips 3815.
superchips 3815.
www.superchips.com
shop around. if you buy a new one, try to get it for $250 or less. if you buy one used, be sure you understand how they work and the VIN locked process and guard against buying one that's VIN locked, otherwise you're hosed.
i bought one here for $230. they have none currently listed, but worth calling.
http://stores.ebay.com/Chip-My-Ride_...LH_TitleDesc=1
http://cgi.ebay.com/ebaymotors/Super...item33597e8d38
shift points - TC and OD only.
mpg - i didn't notice any improvement.
speedo/tires - yes.
eliminate death flash - yes.
causes pinging if you have bad plenum - yes.
speedo/tires - yes.
