Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram Tech
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read Used CarsGarageVendors TSB & Recalls
Welcome to DodgeForum.com
Thread Tools Search this Thread
Old 06-09-2010, 05:31 PM
BowlerGT BowlerGT is offline
Garage is empty, add now
Vehicle: 1996 Ram 1500 and 1994 Mustang GT
Default Truck Is Bucking
Ok I havnt driven my truck since I bought it a few weeks ago, now Ive gone out and started it a few times and its fine, when I drove it home it drove great. All Ive done to it since I broght it home is put a muffler on it. Just went to leave to have new tires put on it, it reversed out of the driveway no problem but soon as I gave it gas in drive rpms drop to like 400 and it starts trying to stall and bucks real bad, if I let off the gas it will start going just fine but soon as I try to give it gas at all it does it again what do you guys think? In idle it is fine, if I rev it in park it is fine.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 06-09-2010, 05:39 PM
UnregisteredUser's Avatar
UnregisteredUser UnregisteredUser is offline
1998 Dodge Ram 1500
Vehicle: 1998 Dodge Ram 1500 5.9l 4x4
That's not a lot to go on, but my first instinct is a failed catalytic converter.
Old 06-09-2010, 05:54 PM
Ok just went back out and drove it back and forth in the driveway and it doesnt seem to be doing it anymore I can give it gas and it goes without any rpm drop or problems, but now when I put it in drive it is fine but when I put it in reverse it seems to engage really hard jerking the truck back if I'm not all the way on the brake pedal
Old 06-09-2010, 09:43 PM
Leaving for vacation friday any input would be greatly appreciated. I did go out and pull out a plug it didnt look that bad, air filter was a little dirty, trany fluid still looked red and didnt smell burnt
Old 06-09-2010, 10:02 PM
1998 Dodge Ram 1500
That's still not a lot to go on... but it is starting to sound like a transmission malfunction. Has it lit the check engine light or set any failure codes? Heck, even if you haven't seen a CEL it would make good sense to get a scan tool on it to see if it has anything stored or pending.
Old 06-09-2010, 10:12 PM
No check engine light
Old 06-10-2010, 12:54 PM
Asked some guys at work today, my seal around the back of the engine bay where the hood comes down was partially pulled off and its sat through a few really heavy rain storms the past 2 weeks, they said water gets down on the distributor could that of been the issue? I'll probably do a tune up here and see if that helps, btw what idiot at dodge put the distributor on the back of the engine where you cant get to?
Old 06-10-2010, 01:42 PM
HeyYou HeyYou is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 1996 Dodge Ram 2500
Well, it was either in the back where its fun to get to (have you seen the newer ford trucks? at least on the dodge, you can SEE the damn thing...) or up in front where it gets splashed with everything coming at you. Not a good scene if you do water crossings at all.
Possibly TPS, possibly trans. What does your fluid look like? Be sure to check it in Neutral, on a flat surface.
Old 06-10-2010, 03:25 PM
I checked it, not on a completely flat surface as my driveway has a slight slant to it, had a nice reddish tint didn't look or smell burnt, and I also did not check it in neutral
Old 06-10-2010, 03:28 PM
zman17's Avatar
zman17 zman17 is offline
Section Moderator
2000 Dodge Ram 2500
Vehicle: 2000 2500HD 4x4 5.9
Then you didnt really check it.
__________________
2000 2500HD 4X4 5.9 and 4:10's,HF tuned SCT,Red-Head gear box, HS 1.7's,
50mm Fastman TB, Hughes Plate,2" Hell Bent ,Volant CAI
Flowmaster 50 series, Rock Solid Ram Steering fix,B&M trans cooler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
