lowering 2001 ram as cheap as possible
Old 04-18-2013, 06:19 PM
jmbishop's Avatar
jmbishop
jmbishop is offline
Default lowering 2001 ram as cheap as possible
I want to lower my truck, I don't haul anything with my truck anymore but would like to if I had the need to. There is also a car show coming up on the 4th that I've been dragged into setting up.
I want to cut the springs in the front but dont know how many coils I can cut to get x number of inches.
On the rear I thought I remembered seeing a thread about flipping a leaf mount but im on my phone and the google search is weak.
Old 04-18-2013, 06:45 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
you cant flip the leaf mount for lower it only raise it make bigger leaf spring shackles and cut the coils depending on height
Old 04-18-2013, 07:13 PM
kejobe's Avatar
kejobe
kejobe is offline
Flip the rear axle so it's on top of the spring. Have to search too see how it's done. Cut the front springs. Cut one coil off both and see how it looks. Want lower? Cut another coil off. Just remember, you can't add the coil back if you go too low. You'll need new coils.
Old 04-18-2013, 07:28 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
it is cheaper to make drop shackles to flip the axle can get expensive quick
Old 04-18-2013, 07:32 PM
kejobe's Avatar
kejobe
kejobe is offline
I've never done it, sooo I don't know. I'll take your word for it.
Old 04-18-2013, 11:49 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
of course it make areal difference what area your in here n the rust belt its easy to break stuff
Old 04-19-2013, 07:51 AM
Z.rawk95's Avatar
Z.rawk95
Z.rawk95 is offline
Drop shackles are only like $40 or something. Thats 2" for pretty cheap, but I dont know how low you want to go.
Old 04-19-2013, 08:43 AM
jmbishop's Avatar
jmbishop
jmbishop is offline
I really dont know how low I want to go because I dont know how low I can go before it makes it unusable as a truck. Ide also prefer not to pull the frond end apart nore than once so id like some input from someone who's cut ram springs before
Old 04-19-2013, 12:46 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
See this thread https://dodgeforum.com/forum/2nd-gen...ering-kit.html
Springs are cheap don't mess with cutting them.
Old 04-19-2013, 11:53 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Put a bunch of rocks in the bed! Worked for me
Or gravel works too...
Quick Reply: lowering 2001 ram as cheap as possible
