Old 08-13-2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Blend door fix
Old 11-26-2010, 02:37 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Umm, read the post above your last one, LOL. Something funny going on with the forum I think. Btw, welcome to DF.
Old 12-16-2010, 02:05 PM
RamMan77's Avatar
RamMan77
RamMan77 is offline
Hey everyone well im also having a problem with my heat my problem i have done my research and everything now im down to two options check the blend door plastic thing or the heater core since the heater core isnt dripping and both lines to and fro are hot im going to guess the blend door well i cant find the damn thing i watched that video a million times and have no idea where it is "98 dodge ram 1500 sport"
Old 12-16-2010, 02:08 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,170 Likes on 2,923 Posts
Bottom of the heater box, just to the passenger side of the trans tunnel, right up against the firewall. Supposedly.
Old 12-16-2010, 04:00 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
That's where it is on my '98 1500 Base.
Old 12-16-2010, 04:05 PM
zman17's Avatar
zman17
zman17 is offline
The cable is actually also adjustable on a 98 and some other years. It's in my 98 FSM. It also says to test the door , by rapidly turning the **** from left to right and you should hear the door slam in both directions.
Old 12-16-2010, 04:39 PM
HeyYou is offline
Cable? I didn't think there was a cable?
Old 12-16-2010, 04:55 PM
zman17's Avatar
zman17
zman17 is offline
Later models use an electric motor. 2000 and 2001 for sure, I don't know about 99.
Old 12-16-2010, 05:06 PM
HeyYou is offline
By Cracky, you are RIGHT! Coolness. My 96 is indeed cable controlled. (explains a bit....) I don't suppose I could talk you into uploading a scan of that particular procedure, and where the various bits are could I?
Old 12-16-2010, 05:11 PM
zman17's Avatar
zman17
zman17 is offline
If you do a search for every post I have ever made, you might find it. But I'll look and see if I have it on PBucket.
Old 12-16-2010, 05:15 PM
zman17's Avatar
zman17
zman17 is offline
I found it, still on PBucket . If you can read it.
Quick Reply: Blend door fix
