OBD2 Code P0441 for Evaporative Emission Control System Incorrect Purge Flow
Just throwing this out there. I'm getting that same code. A smoke test showed that it was a bad leak detection pump. That's under the hood, passenger side, near the front corner so it's easy to replace. I haven't done it yet but hopefully that'll solve my problem. Maybe yours? Have you had a smoke test done? If you have vacuum leaks then I'd advise you get one done.
I had mine smoke tested when
I had that problem, but since right now 80% of his lines are probably full of charcoal a smoke test would be a waste of money, Like I wasted on mine. Until you get thosde lines clean theres no point, especially if youve already verified the canister is broken.
P04410d
I just changed the clutch out over the weekend... Now getting this error...there was one vacuum hose coming from transfer case on up that appeared to have a check valve that came apart but we slid it back together...unless it didn't just come apart and broke...but it slid in...code says P0441 control unit? Help?
'97 Dodge Ram 2500 ...5.9 Magnum... 5-speed...
The following users liked this post:
Mousey1432 (09-02-2020)
P04410d
Ok that's a good thing...and what I thought...I had no codes at all before doing the clutch...so the big armed guy I had top end reaching down to find the other end of the the vacuum hose probably just knocked a hose off or loose..cause I just changed my purge valve about 3 months ago and canister last year... so I just need to trace hoses from purge valve back... Thank you!
