Knocking noise
no you don't need to replace the evap canister. its just a can of charcoal and air.
you can get the purge solenoid at autozone for about 40 bucks for an 01.
http://www.autozone.com/autozone/par...mString=search
you haven't hurt anything. the purge solenoid opens a valve which allows engine vacuum to pull vapors from the evap canister. it also monitors the pressure somehow. i don't know what the knocking would be, maybe the engine vac is rattling the valve back and forth or something.
