99 5.2L V-8 What is the normal oil pressure reading
Old 11-24-2010, 07:27 PM
justjoe906's Avatar
justjoe906
justjoe906 is offline
Default 99 5.2L V-8 What is the normal oil pressure reading
Oil pressure reading 30 is that about where it should be for this model.
Also own 98 Ram with V6 motor and it is always 50 or higher
Thanks
Old 11-24-2010, 07:31 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
It that at idle? Or cruising down the road?
V-6s generally do run higher pressures.
Old 11-24-2010, 08:10 PM
J415's Avatar
J415
J415 is offline
"Normal" for me is 40.
Old 11-24-2010, 09:00 PM
Saber6's Avatar
Saber6
Saber6 is offline
I'm normally at 50 or so.
Old 11-24-2010, 09:01 PM
Gerehead8's Avatar
Gerehead8
Gerehead8 is offline
Minimum factory specs are 7 psi at curb idle (in neutral) and 30 psi at 3000 rpm. This is on a mechanical gauge though. Don't believe the electrical gauge in the dash. It pretty much only tells you that you have pressure, not what it is.
Quick Reply: 99 5.2L V-8 What is the normal oil pressure reading
