There's the gear sets in there for lo range, and the shift mechanism, but yeah, that's basically it. Drop it out, rip it apart, see what you need, get parts, fix it, put it back. Take a VERY good look at the case itself though..... when they go, they tend to take the casing with 'em.
It's not that easy! The front output shaft flange needs to come off also, so you can slide the shaft back to get the chain on. I suggest you take the TC out of the truck, takes an hour or so. This way you can work on it on a bench.
ok i need to know what parts need to be ordered, that way i can have her out of the truck and back in, in one day. so besides 1.25" chain and mode fork pads (i dont beleive range fork pads are changeable) what else do i need to order?
i was under the impression that some trans RTV (bad luck with ultra black) would do the trick for everything including the case halves. what requires an actual seal instead of RTV?
