120amp fuse mean I have a 117amp alternator?
Old 01-06-2011, 04:51 PM
Mudshack's Avatar
Mudshack
Mudshack is offline
Default 120amp fuse mean I have a 117amp alternator?
Sorry for the quick question without a search. I only have 2 min in front of the computer.
I checked my fuse box and it has a 120amp fuse for the alternator. Does that mean the alternator that I need to buy has to be a 117amp? Or is it as easy as bying a 140amp fuse and getting a 136amp alternator?
Old 01-06-2011, 05:03 PM
grox's Avatar
grox
grox is offline
You probably have a 90 amp alternator. If you can find a 140 amp fuse, then go ahead and buy a 120 amp or 136 amp alternator
Old 01-06-2011, 05:42 PM
slider15004x4's Avatar
slider15004x4
slider15004x4 is offline
Mine truck had a 120A fuse and my alternator was a 117A, but I replaced it with a 136A and left the 120A fuse in because it's a slow blow.
Old 01-06-2011, 05:47 PM
Mudshack's Avatar
Mudshack
Mudshack is offline
O'Reilly Auto Parts only offers 90amp and 136amp alternators for the truck. Can the wireing handle the 136amp alternator if I upgrade to a 140amp fuse? Or will I melt some wires? And do all three have the same bolt configurations and belt pully?
Old 01-06-2011, 06:40 PM
slider15004x4
Mine was a direct replacement. From what I understand, the wiring didn't change between the different alternator choices. I'm leaving my 120A fuse in until I find a reason that I need to upgrade it to the 140A. Maybe someone else knows differently about the wiring, but I doubt they would use a completely different wiring harness because of the alternator.
Old 01-06-2011, 06:57 PM
Mudshack's Avatar
Mudshack
Mudshack is offline
But isn't running 136amp thru a 120fuse asking for trouble? If it blows while driving......not good. I don't know how much a 140fuse costs but it has to be pennies compared to the potential costs if you blow a fuse. Correct me if I am wrong. I generally steer clear of electrical issues.
Old 01-06-2011, 07:24 PM
grox's Avatar
grox
grox is offline
The potential cost if you blow a fuse is the cost of a new fuse.
Old 01-06-2011, 07:29 PM
97black_ram's Avatar
97black_ram
97black_ram is offline
The voltage regulator regulates the output of the alternator based on the load (ie. stereo, Off-Road lights, winch, etc). So if you have your truck all decked out with a big stereo, a higher output alternator is needed to keep up with charging the battery and running the equipment.
Old 01-06-2011, 07:53 PM
Mudshack's Avatar
Mudshack
Mudshack is offline
I get that. That is not the issue. The issue is, I need to replace my alternator which is the stock 117amp. And my local auto parts store only carries 90amp or 136amp. I am running an all stock truck so no issues in needed extra juice.
Old 01-06-2011, 08:13 PM
slider15004x4
The only way you are going to blow the 120A fuse is if you are running a ton of aftermarket lights or big stereo equipment. I have none of that now, so I don't have to worry about blowing the fuse. When I do add aftermarket off road lights and the such I will put in the higher fuse. Just get the 136A, it's always nice to have the extra capacity for the future and it will not cause you any problems.
Quick Reply: 120amp fuse mean I have a 117amp alternator?
