Old 08-13-2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
blend door actuator
Old 01-06-2011, 07:12 PM
offroadjosh's Avatar
offroadjosh
offroadjosh is offline
Default blend door actuator
Still no heat sooo im just gunna replace the blend door actuator, but i cannot find it.. I looked all over on the pass side near the tranny hump... I cant find anything that resembles the actuator to remove.. Any one got an exact location???
Old 01-06-2011, 07:34 PM
outdoortoys's Avatar
outdoortoys
outdoortoys is offline
Not shure on a 96 but my 99 is right at the junction of the trans hump and firewall just on the passenger side of the hump crest. It has a wiring plug(I think two wire) going in from the bottom.
Old 01-06-2011, 07:55 PM
offroadjosh
How the hell am i supposed to get back there? its all covered up?
Old 01-06-2011, 08:20 PM
outdoortoys
Old 01-06-2011, 08:30 PM
offroadjosh
thanks but i been watching those videos for over an hour over and over and still couldn't find it.. sooo I went out to the 02 cummins and looked and found it right away... So its in a different spot on my 1996=/ Blah! Anyone now where?
Old 01-06-2011, 09:47 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Is your truck a 96? No blend door actuator motor for YOU! Cable operated. In the spot where the little motor is on the newer trucks, the axle for the blend door sticks out a bit. You should be able to feel it move as you cycle the temp control from hot to cold.
At one point, I had a bookmark to the procedure to adjust the cable. (and it was actually pretty easy.....) But, I am unable to come up with it now? It was posted right here on these forums, I think it was either J415, or ZMAN.......
Old 01-06-2011, 10:35 PM
offroadjosh
OH!!! That makes me feel better... and worse hahah.. Im out of ideas to whats wrong now :P and yea i got a 96 lol... so if the system has been flushed, all new hoses... water pump has good flow(not over heating), new working t-stat... blend doors open and close.. blower motor is clean.. im at a total loss... there has got to e a reason my heat blows goats...
Old 01-06-2011, 10:38 PM
Don't feel too bad..... I went looking for it several times..... and for some reason, just couldn't find it.
Old 01-06-2011, 10:44 PM
offroadjosh
haha! I was like wtf its right here on the 2002 cummins!!! Then i found something that sorta looked like it.. and pull that off and it was this white rectangle ceramic thing... idk wtf that was lol(i put it back carefully hahah).
Old 01-07-2011, 07:03 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The ceramic thing is the blower motor resistor and here are the directions for adjusting the cable, from the 98 FSM.
Quick Reply: blend door actuator
