tire/wheel question? pleas help!
Old 01-15-2011, 11:07 PM
99ram15005.9's Avatar
99ram15005.9
99ram15005.9 is offline
Question Tire/wheel question? Please help!
Will 315/70 r17 tires, ruffly a 34in tire on 3gen stock wheels fit on my 99 1500 with a 3in suspension lift which includes spacers and shocks and rear aal's. I have stock control arms just wondering if these would rub real bad or not at all, thanks. Do i need to get spacers? Here is pics of the wheel and tire combo if they upload.
Old 01-16-2011, 08:03 AM
thompson1986's Avatar
thompson1986
thompson1986 is offline
yeah they shoudl fit jsut fine, its the width that caused problems for me 33x13.5 r16 rubbed control arms on tighter turns. i bought some rims with 3 3/4 inches of backspacing, no rubbing.
Old 01-16-2011, 12:11 PM
dipsherry's Avatar
dipsherry
dipsherry is offline
mine fit my 2wd with abot 3 inches of lift...i only rub on tight tight tuns
Old 01-16-2011, 04:27 PM
olyelr's Avatar
olyelr
olyelr is offline
You will surely rub on the control arms, but that will be minimal and easily avoided. It will also be quite close to your fender (the back portion of the front fenders), but will most likely clear.
Old 01-16-2011, 04:49 PM
99ram15005.9
Ok so how would i avoid it rubbing the control arms then?
Old 01-16-2011, 06:19 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
less backspacing on the wheels. of course, that makes them stick out further, and more likely to rub on the bumper, or rear of the wheel well.
Old 01-17-2011, 07:11 AM
olyelr's Avatar
olyelr
olyelr is offline
Your choices are; new wheels with less backspacing, wheel spacers with your current wheels, or somehow adjusting the steering to prevent full lock.
I have heard some 2nd gens have adjusters on the axle to allow some adjustment to how far you can turn the knuckles... my truck didn't, and many do not.
And like that crazy fella above me stated, with a wider stance (weather its with wheels or spacers) may cause rubbing on the fender. Honestly, I very quickly got used to it and just simply didn't steer it at full lock anymore. Its so minimal, I'm pretty sure it didn't even effect the overall steering radius.
Quick Reply: tire/wheel question? pleas help!
