5/16" square socket required for band adjustment? - DodgeForum.com
Old 03-01-2011, 01:54 PM
chrscott's Avatar
chrscott
chrscott is offline
Default 5/16" square socket required for band adjustment?
Looking at adjusting my trans bands, and have read that a 5/16" square socket is required for adjustment of the rear band in the pan.
Can someone confirm if this is true for a 2001 46re?
The FSM says I can adjust the front band using a torx bit (which I have), but is a little ambiguous on what to use for the rear band. I have read a couple write ups, and it seems some mention the 5/16" square socket (some don't say).
Also, I am having a bitch of a time trying to find a square socket.
I found a 5/16" npt pipe lug socket, but I am not sure if it will work (haven't measure it yet), as all pipe sizes seem to be slightly off their nominal dimension. Anyone use one of these with any luck?
Anyone know of a good place to get a 5/16" square socket?
Or a method to make one?
Thanks,
Chris
Old 03-01-2011, 02:33 PM
nolazach's Avatar
nolazach
nolazach is offline
I used a regular socket 5/16ths I think, it did sorta jam on, but it wiggled off, didn't strip or anything..
Old 03-01-2011, 02:53 PM
Gerehead8
Gerehead8 is offline
I have used regular sockets before and they have worked but I also nearly stripped the adjuster using one once too. Square sockets are not uncommon, I think mine are Craftsman. They look very similar to torx socket but have 8 points if I remember correctly.
Old 03-01-2011, 02:54 PM
chrscott's Avatar
chrscott
chrscott is offline
Yeah, I did consider that, but I was worried about stripping the head off of it. That would really ruin my day.
I know 72 in*lbs isn't much, but I would prefer to find the proper socket (or something close), if possible.
I am not in a huge rush to get it adjusted, but it is time for it to be done.
Old 03-01-2011, 02:57 PM
nolazach's Avatar
nolazach
nolazach is offline
If no rush here is one for $4...
http://www.ntxtools.com/network-tool...PC-1010FP.html
The drive size is in the pic, its 3/8 x 5/16
Quote:
K`s pipe plug sockets are ideal for the removal of manual transmissions, transfer case, engine oil pan, differential housing drain, fill plugs and various other applications for both foreign and domestic vehicles
I had my transmission out when I adjusted mine, and was too lazy to run to the store to get one...
Old 03-02-2011, 01:21 PM
chrscott's Avatar
chrscott
chrscott is offline
Thanks for the info Nolazach and Gerehead.
Related Topics
Thread
Forum
Replies
Last Post
Mexii88
2nd Gen Neon
2
11-08-2015 03:10 PM
johnwartjr
Dodge Caravan
1
10-21-2015 09:19 PM
70383roadrunner
2nd Gen Neon
3
10-10-2015 03:28 PM
usmc1811
Brand News, Concepts & Rumors
5
10-05-2015 01:33 PM
PaulMcKIII
2nd Gen Ram Tech
3
09-30-2015 10:49 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
