Cruise control problem
Old 08-21-2011, 11:04 AM
chastain90's Avatar
chastain90
chastain90 is offline
Default Cruise control problem
My cruise control stopped working and I have seen some threads about the vaccum problems with them and I checked mine and the fittings seem to be good and I check the 2 lines and I didnt see no problems is there anything else I might need to check? I also have the wild vents so I know there is a leak somewhere. Thanks
Old 08-21-2011, 11:06 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
does your cruise do anything at all?
Old 08-21-2011, 11:40 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Until the vacuum leak is addressed, I see no point in trying to diagnose it any further. You say you checked the fittings, what about the lines and the check valves themselves? https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old 08-21-2011, 02:40 PM
chastain90's Avatar
chastain90
no the light comes on when you turn cruise on but other than that it does nothing. and I have checked the lines I just dont know what else to check I havent checked the check valves tho where are they?
Old 08-21-2011, 02:49 PM
zman17's Avatar
zman17
zman17 is offline
Read the thread that has been provided, if you have not done so.
Old 08-21-2011, 02:53 PM
chastain90's Avatar
chastain90
I did should have posted after I read it thanks
Quick Reply: Cruise control problem
