End-all Be-all plenum thread
Old 08-25-2011, 09:46 PM
nmason's Avatar
nmason
nmason is offline
haha, i just went back and read all the wonderful typos. greasy fingers and touchscreen dont jive.
still have an issue. i thinkt eh rear gasket on the intake was nudges when i reinstalled it. have an oil leak. coming down onto the tranny. pull it off again tomorrow, reseat, reinstall, done. think im good.
  #112
Old 08-28-2011, 07:47 PM
nmason's Avatar
nmason
nmason is offline
tip: check the connectors on the temp sensors on the front of the intake. one of mine failed, plastic very brittle, and i have to splice in a new one. truck will only start when cold without it. these connectors dont seem to be very strong after 300000km.
  #113
Old 09-15-2011, 01:51 PM
David_D's Avatar
David_D
David_D is offline
Does anyone know what size the bolts that need to be replaced are and how many? Btw been stalking the forum for awhile and have really learned alot!
  #114
Old 09-15-2011, 02:39 PM
gdstock's Avatar
gdstock
gdstock is offline
If you are talking about the bolts for the pan, there are 15. They are 1/4" grade 8 but I do not remember the length (already installed plate). They are slighly longer than original as the aluminum pan is als 1/4" thick. Depending on where you buy the plate, bolts oftem are included. Make sure you clean out bolt holes first and use thread lock!
  #115
Old 09-15-2011, 04:56 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I'm sure it has already been mentioned in this thread, But,
TIP: Assuming you are using new intake bolts(i'm not talking pan bolts) like you are suppose to. Cut the heads off a couple or four old ones, screw them in a little and use them as guides to seat the intake. If you leave them long enough, you just unscrew them by hand. If not, cut a slot in the end and you can use a screwdriver to remove them.
I know this has been mentioned, but somehow I doubt anyone reads the whole thread.
  #116
Old 09-25-2011, 03:03 PM
FreeDodge's Avatar
FreeDodge
FreeDodge is offline
I also have been studying this thread some, along with other write ups and videos. I have a 94 ram 5.2. Once I get home from work today, I will be doing the checks for the plenum but plan on doing it regardless. I am really new at this stuff and don't have much experience but will be picking the brains of family members who are. My truck was free from a family member has about 172k miles on it. It blows a little smoke when shifting, I always smell a burnt oil/fuel smell. This morning, when it was idling I noticed it smoking some. Like I said still learning but I appreciate the available info...excited to get started but like others have said, I am really nervous about breaking a bolt which sounds like will happen. Will probably be asking questions! =D
  #117
Old 09-28-2011, 04:13 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Someone please remind me, does the blown plenum cause a slow 4WD engagement due to loss of vacuum?
  #118
Old 09-28-2011, 04:34 PM
dodge dude94
4LO doesn't really have a problem, 4HI seems slow.
Unless maybe it's just me. Anyone wanna take a video for me? lol
  #119
Old 09-28-2011, 04:46 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
shouldn't. I have seen that more due to burrs and such on the axle shafts/collar. Or, low vacuum because of an external leak.
  #120
Old 10-02-2011, 10:07 PM
Tazman89's Avatar
Tazman89
Tazman89 is offline
Well I did it! the plenum is in no broken bolts all sensors are back together and it is running fine but now I have a check engine light on so tomorrow im gonna have it scanned and see what it is!
Quick Reply: End-all Be-all plenum thread
