End-all Be-all plenum thread
#501
#502
I got the hughes kit, but, there was nothing on my bolts..... I just picked up some blue lok-tite at the parts store.
You want to make sure all the bolts/holes you need to torque to spec are nice and clean. I bought new IM bolts, and ran a tap down the holes..... I haven't had any issues with mine. Been about a year now I think...
#503
Thanks, once again HeyYou! I've had a cat go bad on me in the past, so I'm familar with pulling the pre cat sensor. Just an FYI for anyone who reads this..My cat failed a few weeks back and lost all power. I was down the street from my house and I pulled the pre cat sensor (mine screws directly into the cat) thinking that would at least get me up that slight hill and around the corner. No such luck! Total cloggage! Truck wouldn't run. Had to have it towed..so close yet so far. Next day I broke out the trusty o'l sawzall & cut the cat out and she fired right up...moral of the story, just pulling the O2 sensor doesn't always mean you be able to diagnose an issue..and In my case the failure of the catalytic converter, massive oil consumption and #8 misfire are a result of a bad plenum gasket
#504
Pulling the O2 sensor will only relieve some of the exhaust pressure, so if it is totally clogged like yours, you are correct. Still not enough air flow to provide for combustion - so no run! But if cat is only beginning to get clogged, it is a good, wuick and inexpensive diagnotic procedure....most of the time!
#506
The SCT tune is a good investment. Removes death flash and improves performance. I did modify my kegger, but would have done the SCT either way. I unsderstand you have to buy the tuner. Once used, it logs the VIN and will not work on another VIN. Just what I have heard or read....don't know for sure.
#508
I'm kinda stuck...I can't pull the fuel injectors/rail..are they that tuff to get out, should I really put real the hell out of them? I planned on pulling them out of the IM and tying it/them back. But now I'm thinking I should pick up the fuel line tool and taking the FI rail/IM out as an assembly. Advice, tips, help! plaese!
#509
