End-all Be-all plenum thread
  #511
Old 07-01-2012, 11:08 PM
gdstock's Avatar
gdstock
gdstock is offline
May soak it in PB or something. Any dirt or corrosion in the bore abouve the O-Rings will make it difficult to pull out.
  #512
Old 07-02-2012, 10:08 AM
It's Me Patt's Avatar
It's Me Patt
It's Me Patt is offline
Thanks again TR Fan, the PB worked with the injectors/rail...Next PROBLEM, I PB blasted the IM bolts, tapped on them again and the first one snapped. (head only). First question does anyone know (for sure) does the IM bolt holes on the IM have threads or are the smooth...PLEASE say smooth, but don't lie, I can handle the truth
  #513
Old 07-02-2012, 11:06 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,166 Likes on 2,920 Posts
Threaded all the way up. Also, the four end bolts (front two, back two) stick out into open air, not into the valley on the engine.... so, they tend to be problematic...... You can still lift the intake off of them though.
  #514
Old 07-02-2012, 11:27 AM
It's Me Patt
that's not what I wanted to hear Just snapped the second head off & I'm betting the rest will do the same...But your saying I can get the IM off with the heads all snapped?
  #515
Old 07-02-2012, 12:47 PM
HeyYou is offline
Max that will snap off is four, I should think. And look at it this way...... at least there will be plenty to grab ahold of to extract them once the manifold is out of the way.
  #516
Old 07-02-2012, 04:46 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
And don't use PB. Get some Cyclo Breakaway at least. And once you get a hold of the stud with something, shake, wiggle and turn it in both directions(as in tighten and loosen).
  #517
Old 07-02-2012, 05:55 PM
It's Me Patt
To late I already use the PB on them..that's the first I heard not to..Well I did get the other ten IM bolts out..Off to work on those two broken ones...Thanks for the tips guys!
  #518
Old 07-02-2012, 05:58 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
at least your not trying to use wd40. pb blaster i better than nothing at all.
  #519
Old 07-02-2012, 10:16 PM
It's Me Patt
Yeah no WD-40 over here..So I center punched the broken bolts, drilled holes and tapped in an extractor. And, it snapped it off (I used the fluted type too) Anyways, I didn't realize but the IM bolt holes aren't threaded so I'm hoping to get the one bolt out and try to lift the IM up off the last one...as usual simplicity eludes me..
  #520
Old 07-02-2012, 10:26 PM
gdstock's Avatar
gdstock
gdstock is offline
Once the bolts are removed (either backed out or broken off) the IM will lift off. It is easier to get the broken ones with IM out of the way. I used vice grips and lots of chemicals and time. Don;t get in a rush...take you time.
Quick Reply: End-all Be-all plenum thread
