New CD Deck issues
Old 04-15-2011, 10:37 PM
CappinHoff's Avatar
CappinHoff
CappinHoff is offline
Default New CD Deck issues
My OEM CD Player stopped playing CD's so I bought a new deck. It's a Kenwood KDC-HD548U. I also bought the wiring harness and installation kit.
I connect the harness and it turns on and is functional. Except there is no sound. I tried the old radio to make sure, and the speakers work. I double checked the wiring harness and all the wires are properly connected.
Anyone else have issues like this?
Old 04-15-2011, 10:40 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
I had a kenwood that would turn on and off for no reason. Found out that the ground was not into a good source.
It is probably your ground being bad.
Old 04-15-2011, 11:36 PM
CappinHoff's Avatar
CappinHoff
That would also cause it to be on but no sound? So to fix that do I just wire a ground from the deck to some metal?
Old 04-16-2011, 01:04 AM
CPTAFW163's Avatar
CPTAFW163
yeah, make sure that whatever the ground is connected to, actually is a GOOD ground. A bad ground can still have it go on, but it will function improperly.
Just because it is clipped to metal, does not mean that the metal is connected to the rest of the truck. I first fixed it to the metal on the ash tray bracket....but that was connected to the PLASTIC dash. thus, a bad ground.
Old 04-16-2011, 01:12 AM
TryMeImHard's Avatar
TryMeImHard
TryMeImHard is offline
hey just some input if you have the infinity set up you have to connect the remote it should be a solid blue on the harness you bought and connect it to your power antenna wire coming out of radio.. i think it is blue with a white stripe maybe light blue..
i just did mine like 2 months ago..
Old 04-16-2011, 01:15 AM
TryMeImHard
oh and make sure you dont conect the antenna wire to the antenna wire on the harness because you dont have a power antenna it doesnt plug into anything
Old 04-16-2011, 01:18 AM
CappinHoff's Avatar
CappinHoff
Ok I have 3 extra wires not used on the harness.
Steering Wheel Remote Input Light blue/yellow
Power Control Blue/White
Antenna Control Blue
So which do I connect to the power antenna on the radio?
Old 04-16-2011, 01:23 AM
TryMeImHard
do you have infinty?? there isnt one that is all the way at end of clip??
Old 04-16-2011, 01:29 AM
CappinHoff's Avatar
CappinHoff
Yeah I got the infinity. On the harness from the truck I have 1 blue wire that says power antenna.
Old 04-16-2011, 01:34 AM
TryMeImHard
alright mine is a 95 so im not sure how much they changed but give me about 15min i will go take a look at mine and some pics for you be right back
Quick Reply: New CD Deck issues
