Old 08-05-2015, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Body Work ??? How to replace front fender
Old 05-05-2011, 08:04 PM
99ram15005.9's Avatar
99ram15005.9
99ram15005.9 is offline
Exclamation Body Work ??? How to replace front fender
How do i replace front fender i know it will be alot cheaper to buy a fender and have it painted and i install it than have a body shop do all the work. i tried to take it off and never cud figure ouut how to get it off. i took out all the bolts holding it on that i could find, but it looks like it is somehow attached to the fenderwell. Kinda like it was pressed together. Heres some pictures it is the little circle lookin things. haha
Size:  63.4 KBName:  100_0311.jpg
Size:  44.2 KBName:  100_0310.jpg
Size:  58.4 KBName:  100_0309.jpg
Old 05-05-2011, 08:45 PM
rollinlow's Avatar
rollinlow
rollinlow is offline
theres bolts all over the place cant rem exactly but it is a bolt on fender the circles are spot welds do not cut them drill them or grind them out that is completely useless probably have to remove the black plastic inner fenderwell as well.
Old 05-05-2011, 09:08 PM
Gerehead8's Avatar
Gerehead8
Gerehead8 is offline
You can remove the inner and outer fender as an assembly but in order to get the outer one off the inner one you have to drill out all the spot welds.
It would be a lot easier to just get a junkyard inner and outer fender assembly.
Old 05-05-2011, 09:15 PM
Dycrow27's Avatar
Dycrow27
Dycrow27 is offline
Mine was the same way it was 10x worse though. from the PO. But, it is actually very easy to take off just a pain to put on. There should be 5 or 6 bolts by the radiator then the ones on top were the hood closes. Then you have to take off the black fenderwell lining. Heres a link it took me like 2 hours from start to finish. Just make sure its lined up properly...
http://www.ehow.com/how_6214354_remo...00-pickup.html
Old 05-05-2011, 09:47 PM
slofr8's Avatar
slofr8
slofr8 is offline
I just went through this. My fender was too rusted to fix so I got one off of e-bay for $114 delivered. When I took my old one off I realized I had to swap the wheel well. I can't find it now but there is a vid on you tube that shows this. He drilled all of the spot welds and, like me, the guy didn't have a welder so he used self drilling tek screews in each hole. It was a pain to take it off and all but not real bad.
Good luck. Dan.
Old 05-05-2011, 10:11 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
There's like 6 bolts holding to the core support and another 5 or 6 across the top. If you lay on your back behind the wheel and push the black inner fender towards the front of the truck you'll see you're bolt you can't find lol. Took me awhile to find it too.
Been there lol. If drill the spot welds out go buy a spot weld remover. They make a world of difference.
Old 05-05-2011, 10:12 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
There's also a bolt at the bottom of the fender.
Old 05-07-2011, 08:31 AM
99ram15005.9
alright so what yall are saying is just go to the junkyard and buy the whole fender assembly the wheel well and fender? Also is there anything i need to know about getting painted like what kind of paint, clearcoat to ask for or anything like tht? I will have to take it somewhere to get it painted cause i want it done right. thanks
Old 05-07-2011, 12:11 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Best thing to do is go to your local paint supply store and have them scan the paint on the door and mix it from that.
Quick Reply: Body Work ??? How to replace front fender
