Help wiring my projector halo's
I've heard that on projectors its possible to have the halo lit up or not and even though it's hard to tell in my pic they aren't lit up and I don't really know about wiring enough to know how to wire up the halo's. The previous owner of the truck installed them so I'm not even sure of the model but I'm fairly certain I know what they are. If anyone could give me some help on how to wire them I'd appreciate it. thanks
There gonna have some wires on the back side for the halo's and the little leds along the bottom, going to have to pull the lights off for that.
Then you need to decide how you want to wire them
1. Turn on with a switch in cab
2. Turn on with ignition(how mine are wired)
3. Turn on with parking lights(most common)
4. Turn on with head lights
If you chose to have them turn on with the parking lights just splice them into the wiring for the parking light, pretty simple power to power and then ground them. Should have red and black wires from the headlight, black is always ground, your red is power
