1998 Dodge Ram 1500 No reverse..
Old 05-13-2011, 02:20 PM
MDrumm03's Avatar
MDrumm03
MDrumm03 is offline
Default 1998 Dodge Ram 1500 No reverse..
So today I went to go move my truck and I had no reverse.. Just acts like it is neutral pretty much.. I've been reading about what may be wrong with it, someone said that it could be a bad reverse band? But, If thats bad you typically dont have OD and you will have no engine brakeing in 1st and 2nd gear? I could be wrong or may have mis-read.. but my OD still works and I have engine brakeing in 2nd gear but not first.. Could my band possibly just need adjusted or am I going to have to get the tranny rebuilt?.. Also, all my other gears work perfectly..
Thanks a lot.
Old 05-13-2011, 02:43 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
I would be tempted to drop the pan, and see what interesting things you may find in there. If it looks to ugly, might indeed be rebuild time.
Old 05-13-2011, 03:50 PM
MDrumm03's Avatar
MDrumm03
MDrumm03 is offline
Yea, I'm thinking thats what I'm going to do, I'll reply and let you know if anything seems "out of the ordinary". But any other input would be appreciated.
Old 05-13-2011, 07:35 PM
MDrumm03's Avatar
MDrumm03
MDrumm03 is offline
So I think I figured out whats wrong.. I believe that my rear servo is cracked and also it appears that some sort of small ring snapped in there as well?.. Ironic because I think it was the Snap Ring maybe?..Name:  Tranny2.jpg
Old 05-13-2011, 10:47 PM
HeyYou is offline
If that is the reverse apply piston, sure would explain a lot.
Which snap ring..... snapped?
Old 05-13-2011, 11:50 PM
MDrumm03's Avatar
MDrumm03
MDrumm03 is offline
Yes it would sure explain a lot lol, but anyway I have no idea.. I dont know if it was a snap ring or not.. I just guessed haha, but either way I'm gonna talk to a friend who rebuilds transmissions and see what he has to say.. But if I would have to put money on it I would say its because that reverse piston is cracked.. We will see I suppose. :|
Old 12-26-2012, 11:37 AM
liltommy23's Avatar
liltommy23
liltommy23 is offline
Hey new member here i have a 98 ram 1500 5.9 and my reverse just out of the blue is gone like there is nothing to it. When i try and Engage it though it sounds like it wants to but as it gets the that last i guess click? maybe it sounds more like a squish or maybe a small rush of air I want to say like a vacuum hose but i have no idea all my others engage and my 4x4 does and there is no engine brake or anything like that, help?
Old 12-26-2012, 11:47 AM
stewie01's Avatar
stewie01
stewie01 is offline
You could start by checking fluid level, truck at normal operating temp, transmission in N, and see how much fluid you have.
Next thing may be to drop the transmission pan and check for crap floating around in the pan.
Quick Reply: 1998 Dodge Ram 1500 No reverse..
