Hesitation? Misfire? Vibration under light load
#41
That's a misfire louie. What is happening is, the engine is misfiring anyway, but, at 45 mph, you drop into overdrive, and the torque converter clutch locks, so, you have a direct mechanical connection from the engine, all the way to the tires.... So, it gets magnified greatly. Kinda feels like the truck is trying to shake itself apart.
First thing to do, is verify your firing order. I had to check mine four times before I found my mistake. While doing that, re-route the wires per the tech service bulletin you will find about that in the FAQ section here.
Next, some info please. How many miles on the motor you swapped in, and where did you get it from?
Did you remove the crank sensor before pulling/installing the motors? They tend to take a real beating if you don't.
Welcome to DF!
Welcome to DF!
#42
Welcome to DF!
Welcome to DF!
#43
I would take a look at the distributor cap anyway. I had a bad miss, and it was because the contacts in the cap were EXTREMELY carboned up.... Changed cap and rotor, and it started running MUCH better.
I think most of the 'hard' parts, (not electrical) are pretty much exactly the same, from 94 all the way to 02.... Things on the intake changed a bit over the years.... EGR went away in 96, and the center divider disappeared in 98, I think. Aside from that, exactly the same. (in fact, my 96 has a provision for the EGR valve, with a cover plate over it...... 96 never had EGR. )
So, check the cap, see what it looks like. Take it from there.
#44
#45
Welcome to DF!
Welcome to DF!
#46
I had two plug wires switched. It is REALLY hard to see back there, and difficult for me to work back there, due to health issues.... so, simple mistake, and something I continued to overlook, as I "knew" it was right..... So much for that huh?
#47
Aw man it is way to hard to see back there and a pain to do. Thats how I feel though, I know I'm right haha. But I doubt I am and hopefully I figure it out today after work ill post then. Thanks again
#48
#49
Dadgumit man, so I had like 3 hours of daylight and had to go get some stuff but I rerouted them like the paper said, but it only talked about two plugs on each side and kind of showed more about the passenger side. I just kept them all as far away from each other as I could and put the black plastic over every wire inbetween clips. No crossing unless it was a right angle and atleast an inch apart. They were all correct from dist to plug though. When I cranked it up the dreaded hiss came through the intake again so I didn't fix that like I thought i did yesterday. I'm lost.. I bought the performance tool inline spark tester from oreilly so I guess ill try that out tomorrow. I just know when I bought my plugs I got the rc12s that were for the 95 so a 0.005 difference and when I got plug wires they gave me omnispark 9461 and they're the long boot with 90º to dist. The coil wire that came in the pack was weird though it was straight and had a long connector going past the insulator which obviously didn't fit my truck. My ignition coil is supposed to be a 90 on both ends. I ended up using the better one from the two older ones. I just wish it was more obvious. I have the best obd2 harbor freight sells but it does the fuel trim and all that will that help me to diagnose? And maybe where could I find where all the appropriate levels. Thanks again I'm so tired of working on this truck. An extra punch in the gut its supposed to rain here in sunny California for the next 5 days. Ill be under a tarp
#50
