Fuel Pump Relay Question.... - DodgeForum.com
Old 09-13-2011, 11:20 PM
zOOkStEr72
zOOkStEr72 is offline
Exclamation Fuel Pump Relay Question....
I am working on my 99 Ram 1500, with 5.9 Liter Engine. I replaced the fuel pump ( it is working, I tested it ), but when I turn the key forward, to the run position... the pump's not kicking on to prime the system. So, I started checking everything. I chased the wires to the relay box. I skinned the 2 wires, and threw power and a ground to them. The pump kicked on, no problems.
I followed the 2 wires into the relay box, and to the fuel pump relay itself. I made a jumper wire, and touched the 2 contacts ( with the relay removed ) and the pump kicked in again. But, when I have the relay installed, and turn the key forward.... nothing. I have 6 different relays, that I tried in that slot ( out of my 01 Ram ) and none of them kick the pump on. I don't think all my relays are bad... what else could be the problem?
Old 09-13-2011, 11:21 PM
gdstock's Avatar
gdstock
gdstock is offline
Check fuse to control side of relay. Manual in DIY section of this forum.
Old 09-13-2011, 11:45 PM
gdstock's Avatar
gdstock
gdstock is offline
Check Fuse #9, 10A and ASD Relay as well.
Old 09-13-2011, 11:48 PM
zOOkStEr72
I just looked over all the headings in the DIY forum. Can you post the link to the thread your talking about please?
I read two stories that are similar to mine, but neither solved their problem. One guy just ran a wire into the cab, and worked the pump off of a toggle switch instead lol. I actually thought about that, but would rather correct the problem, then rig it.
Old 09-13-2011, 11:54 PM
gdstock's Avatar
gdstock
gdstock is offline
I am not citiing a thread. Using electrical schematic, and past knowledge. (electrical engineering background).
Do you have a Haynes or FSM? Haynes page 12-38.
Old 09-14-2011, 11:23 PM
zOOkStEr72
I checked the #9 fuse, and the ASD relay..... I changed them both, and still nothing.
I recently found a switch above the steering wheel, that I believe to be the roll over switch. This push button switch, seems to be broken. I push it, and it doesn't click, or anything. Going to look over the wiring diagram, to see, where this is supposed to be running to, and from. Right now, the red is hooked to my headlight... that doesn't seem like a factory job. If it were, it would be in the wiring harness.
Old 09-15-2011, 12:16 AM
gdstock's Avatar
gdstock
gdstock is offline
There is a wiring diagram in the 2001 FSM that can be found in the DIY section. Do you have this? It may help. It is more complete that the Haynes.
Old 09-15-2011, 04:18 AM
zOOkStEr72
Yeah, I found it, and downloaded it. Yeah, it's pretty specific all right lol. I'm trying to make sense of the diagrams, but it's like they are in German to me lol. I know basic codes, and diagrams.. but these... are way more than I can comprehend. Giving it, the old college try tho..........
Old 09-15-2011, 11:27 AM
HeyYou is offline
Super Moderator
The diagram on page 8w-30-11 I think is the clearest......
Basically, at the fuel pump relay socket in the pdc, pin 30 should be hot at all times. Pin 86 may be always hot as well, but, should most certainly be hot with the ignition in the run position. Pin 85 goes to the PCM, and should GROUND for three seconds when the key is first turned on. Pin 86 goes to the fuel pump, applying power there should make the pump run.
Related Topics
Thread
Forum
Replies
Last Post
daniel.kirkby
Dodge Stratus
2
05-12-2016 01:57 PM
john_2216
3rd Gen Ram Tech
6
11-09-2015 10:42 PM
Fishman2580
1st Gen Ram Tech
2
08-12-2015 10:03 PM
atkinson290
Dodge Neon
4
07-26-2015 05:45 AM
RM-D150
1st Gen Ram Tech
1
07-04-2015 09:23 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
