96 ram 1500 fuel pump electrical problem
Old 09-28-2011, 11:30 AM
farmerben2000's Avatar
farmerben2000
farmerben2000 is offline
Default 96 ram 1500 fuel pump electrical problem
i have a 96 ram 1500 with the v6 that wouldn't start 1 day. i checked and it had good spark but dry plugs. i couldn't hear the fuel pump come on when i turned the key on so i checked all fuses they were good. i wiggled the wires that connected to the fuel pump then when i turned the key it came on. it ran fine for a couple days then the same problem i disconnected the wires from the fuel pump all the connections look good no corrosion plugged it back in and it worked again. now it has quit again and i cant get it to work again i tested and got 12 volts on the wires for a second when i turn the key on. is there any way to know if its a fuel pump problem or electrical problem i also get trouble code 42.
Old 09-28-2011, 11:32 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Next time it won't start, thump on the bottom of the gas tank. If it will then start, time for a new pump.
Quick Reply: 96 ram 1500 fuel pump electrical problem
