Steering column/shifter linkage.
Old 11-01-2011, 10:32 PM
Hans_GZP's Avatar
Hans_GZP
Hans_GZP is offline
Sounds like you may have installed the bushing in a bit too far. I just did the same thing and had to replace my whole column. I then had to sand down the bushing a bit and only inserted it so that it went 1/4 inch from the lip... then be sure the retaining ring isn't right up against the bushing since the ring will rotate with the shaft, but the bushing is stationary.
Old 11-02-2011, 01:27 PM
SpencerS's Avatar
SpencerS
SpencerS is offline
Yea we backed it off a little bit and it freed itself up out of the bind and that linkage was able to move after that.
Quick Reply: Steering column/shifter linkage.
