Steering column/shifter linkage. - DodgeForum.com
Old 10-28-2011, 03:25 PM
SpencerS
SpencerS is offline
Default Steering column/shifter linkage.
So I pulled the column yesterday and completed the rock solid ram steering fix. Reinstalled it and hooked the linkage up and the column shifter will not move the linkage. I can move it up and down and change the gear with my hand but not on the column.
The steering wheel was tied off and did not rotate, did I break the clock spring or what? How do I fix this?
Edit: 95 ram 360 auto 4x4
Old 10-28-2011, 03:32 PM
HeyYou is offline
Super Moderator
Sounds like something fell off. Clockspring won't have anything to do with it. So long as your airbag lite is off, and the horn/cruise works, that should be fine.
Old 10-28-2011, 03:44 PM
SpencerS
SpencerS is offline
Alright I'll pull the column again and inspect it. I hope I didn't funk up the column.
Any tips on what to look for?
If the column is toast what are my options besides buying a whole new column? Floor shifter conversion?
Old 10-28-2011, 03:51 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You sure you have the linkage hooked back up? They can be a PITA to pop back in.
Old 10-28-2011, 03:56 PM
HeyYou is offline
Super Moderator
Not in the column itself, somewhere on the external linkage. There is very little IN the column to fail.....
Old 10-28-2011, 04:03 PM
zman17's Avatar
zman17
zman17 is offline
Quote:
I had to replace the column on my 98, because the crush joint or whatever it is inside the column broke. Anyway, it's simple. If the you move the shifter and the linkage does not move, the column is hosed. Get one from a JY. The dealer was like 900 bucks at that time. (4 or 5 years ago)
Old 10-28-2011, 04:11 PM
SpencerS
SpencerS is offline
Aww man....oh well ima look at a couple kits for floor shift. I wonder how i broke it. Junkyard trip for sure this week.
Anyway thanks guys.
Old 10-28-2011, 04:14 PM
SpencerS
SpencerS is offline
Is there a diff between 4x4 and 2wd columns? How bout between years and models(2500 ect)?
Old 10-28-2011, 04:20 PM
zman17's Avatar
zman17
zman17 is offline
Quote:
Years will matter, that's all. You sure you installed the bushing correct? I also don't see how you broke anything if it worked fine before.
Old 10-31-2011, 12:27 AM
SpencerS
SpencerS is offline
Well i was able to pound on the linkage and it started working again. But it still binds a little.
Related Topics
Thread
Forum
Replies
Last Post
ComputerJoe
2nd Gen Ram Tech
16
12-24-2015 01:21 PM
groenberg
2nd Gen Ram Tech
16
11-01-2015 03:57 PM
binx30
1st Gen Dakota
1
09-27-2015 12:36 AM
Unoriginal Name
2nd Gen Neon
3
09-24-2015 07:44 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
