Power Mirror Fuse Question
on
Does anyone know what the power mirror fuse is grouped with? Is there even a fuse for the mirror's? I've looked through the service manual and the flip book in the glove box and unless I looked right at it, neither tell me which one the mirror's are in.
There isn't anything related to the mirror's on the inside of the PDC lid or the Fuse panel in the truck.
I just noticed today that my power mirror's don't move anymore. I don't think it is accident related, unless they forgot to plug up the wires, I'll check that next.
I'm thinking I adjusted the mirror's since I've had her back.
There is nothing else electrical that's not working, power windows work, power locks work, the heater blower comes on (issues there but that's not related - blend door, possible wild vents), radio works.
I was thinking maybe they put it on the power windows fuse but since they work the fuse has to be good.
And as of last Tuesday my heated mirror function still worked too, haven't had a need to use it since then.
I'm gonna double check and make sure a wire didn't get pinched or that they did plug it back in.
Any suggestion's?
Any suggestion's?
Fuse 12 in the junction block. (side of the dash) Powers a bunch of other stuff as well though, which I think you would notice not working. (radio, overhead console, vanity lights, if you have them, etc.)
If neither mirror is working in any direction, check the ground wire from the power window switch, its a black with light green trace wire. Manual says the ground is "left lower cowl". Whatever that means. (ok. looks like it is under the trim panel on the body side below the dash. IN the passenger compartment. right by the drivers feet.) There is also a splice by the left door grommet. Either one would be a good place for the wire to break, and cause both mirrors to not do squat.
The following users liked this post:
Moosetifer (08-17-2022)
on
But it was an easy fix, unless they somehow didn't get the clip on all the way and it fell off sometime...
Trending Topics
on
