Old 08-14-2015, 02:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
Brake proportioning valve
Old 06-03-2015, 08:16 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Do the brakes bleed out reasonably well?
  #22
Old 06-08-2015, 03:13 PM
BigGreenRam's Avatar
BigGreenRam
BigGreenRam is offline
Well im not the only one with crazy messed up brakes been working on mine for a while found out master is leaking fluid in to the booster so new master new booster weds as far as bleeding the rears are a steady drip gravity bleed front flow good so I'm thinking the sensor on the proportion valve is throwing the ABS and brake light on cause the presser drop from the master into the booster
  #23
Old 06-08-2015, 03:15 PM
HeyYou is offline
if the proportioning valve has closed off the rear brake circuits, that will indeed annoy the ABS system.
Verify your rear brake circuit is intact..... then have a friend pump up the brakes, and HOLD pressure, while you crack open one of the FRONT bleeders. That should reset the prop valve, and get your rears working again.
  #24
Old 06-08-2015, 03:20 PM
BigGreenRam
Ill do that weds replacing master and booster and flushing the system out
  #25
Old 06-11-2015, 05:32 PM
BigGreenRam
Update new master and booster flushed system have a great peddle now no lights nothing crazy as of yet stops on a dime and leaves change lol thanks for all the help from all y'all on here
Quick Reply: Brake proportioning valve
